[WTB] 8 x 6582 or 8 x 8580 SID
no longer applicable.
Hi Matthias.
You and me both… People are tending to hold on to 6582’s and 8580’s nowadays. You might have to settle for 6581’s as they are more widely available.
Worth checking Ebay periodically though.
Cheers
Phil
Hi Phil,
yes, true but the PCB’s are made for the 9V chips and actually I would have enough 6581 chips… But I want at least 8580 chips…
Cheers
Matt
Hi.
If it is for the MB-6582, that can support any of the SID variants with jumpers to select which voltage to use (and the correct PSU option). I can understand why you would want 8580’s or 6582’s though!
Cheers
Phil
Hey Phil,
thanks for the clarification. I will then start with my 6581 chips :slight_smile:
Cheers
Matt
8580 = 6582 + 1998, observing that nothing much happened in 1998 :slight_smile:
1999 on the other hand… :slight_smile:
