Tried a lot…but nothing worked..somehow…
Made the Motorfader module and i wanted it to test it with the example…but somehow…my voltage-regulator (LM317-220) is not giving the right voltage (what should be 8V (after adjusting with 1k-pot)according to the documentation) out…
Don’t know quite what’s wrong…
Used the .pdf from the site, and every diode is placed in the right way…but something strange is going on…
Measured the voltage of my powersupply on the circuit and that’s was all above 8,5 V on my capacitors, until it went out my LM317-220 then the voltage became 2.2 and 1.5 V.
Soldered it in the same way as the image on the site.. so thought this should be okay…
What’s wrong if everything is okay soldered…And is the LM317-220 indeed a voltage regulator as i claimed  it to be or…is it a current regulator…???
What’s an optional suggestion for trying to get 8V…and the motorfaders running,…A 78L08 or 78L09 (with adjustment?)…
Some little question still:
Is it possible to burn a 16F84A on the JDM? And if yes, how is this achievable…(by using a second socket…and hereby soldering the right legs of the JDM to the optional socket?)
As I read somewhere here on the Forum that it should be possible…to also use 16F877A…and to burn with JDM…but i wasn’t able to…although I was able to burn 18F’s and 16F’s…what’s the difference between the A type and the "normal 16F877?
Somebody…???
Thanks in advance…
Erik
