I’m building an organ console which will contain inside a couple of wall warts powering midibox and two LCD monitors. I’d like to make the whole thing self contained by having a single C14 inlet connected to an internally mounted 4 way block via a on/off switch. Fairly simple wiring but given the high voltage here I’d like to do it carefully and properly. Assuming that I am soldering the connections, what is the best approach to make sure all the soldered connections are well insulated? Should I use use heat sink tubing?
Thanks,
James
