Hi all, for some reason my sammichSID always defaults to bank B on start up, and for the life of me I can never switch back to bank A, I usually fluke it some how but when I use it again it starts up with bank B as default?
Any idea how to have bank A as default start up?
And is there a easy solution to switching banks
I have read the manual but cat put my finger on itā¦
Thanks in advance
Cheers
My way starts from the main menu by pressing āthe LEFTMOST SELECT BUTTON to enter the ensemble root menuā, again the same button to enter the SID menu. Next select button to the right is for bank selection, after pressing it moving the encoder will change the bank.
Saving the newly edited ensemble Iāve the MIDIbox booting in it next time.
Ciao
Hey mate thanks for that!
I can switch banks! yay
How do I save this? it will still boot with bank B on start up?
Cheers
Glad to help
The SAV(e) menu itās also in the ensemble root menu but youāll have to scroll to the right to see it with a 2x20 LCD.
From there āE#: selects the ensemble which should be overwrittenā and "do! stores the ensemble.
Note that naming is not supported. Only the configuration sections of available MBSIDs will be stored.
The last stored ensemble will be reloaded after power-on." according to the manual.
Cheers
Hi ErMangaver, thanks mate for your help!!! got it sorted :frantics:
