I’m looking into a batch of custom wound toroidal transformers for the MB-808 project - they’ll have dual 15V secondaries to provide +/-15V for the analog section PLUS a 5V winding to be used for the digital section. That way, we won’t have to chain a 5V regulator after the 15V section, and it should be fine for devices that require +/-12V and +5V too…
So far, the minimum quantities for custom windings are large (500x) or expensive ($50), so I’m hoping that I can drum up enough interest to go for the quantity and get them at a better price. Here’s the group buy sign up link:
any more details also on the Ampere rating etc? I guess for bigger projects like what I’d use them for, at least 1A on the 15V and 1.5A on the “5V” would be cool.
for the 5V rail, a transformer voltage of 7.5V would be perfect.
Why custom wound? Surely such a thing already exists?
Thats what *I* thought… Haven’t found one yet, and I have…(looks)…eight toroid manufacturers on my contact list so far… Lots of dual secondary stuff out there…
May I suggest 2-3A and 8V? I’m thinking about lots of LEDs…
OK, well, without getting into the whole Root Mean Square thing…
The idea is to be able to provide enough power to work with the regulators we’re using in the MB-808 - 2A for 5V and 15V and 1.5A for -15V. For reference:
I’m probably interested in a couple if the price and postage is right. I’ve put my name on the list to show an interest but would need to know the price (postage) before I commit.
I’d also appreciate some advice on how to wire them up because I’m scared of have respect for mains electricity.
sorry to hi-jack, but if i were to use this for the MBFM project, would i just not use a V-reg on the core since this trafo already puts out +5v? i assume +/_ 15V is just fine for the OPL3 module etc… just curious about the +5V rail.
the xformer outputs 5vac, you still need to rectify and regulate it…
i’m not sure the opl can take ±15v, but current draw is low enough you should be ok with feeding 12v regs from this xformer…
btw, doug, i have had issues w/ using a 7vdc wallwart on the midibox core, which is what you should get from 5vac * 1.414
if it is rated at a higher current than you pull, it could be ok, but it is cutting it a bit fine for the usual 7805…
