Which pin goes where?
hi,
This is probably one of the dumbest questions but I seem to be a bit lost. I am not sure which pin on the potentiometer or sliders go where on the AIN. The sliders have 4 pins labeled 1 -3 (two of them being labeled 2). The pots just have three pins with no numbers? How can i test which one is which? Any link to info would be appreciated.
Thanks
Outer  pins should go to “+” and “-” and inner pin to AIN input
In the type you mention, 2 is usually the slider. 1 and 3 are the ends. A quick check with the ohms range of a testmeter will sort it out. In this case, 2 would go the the AIN, and 1 and 3 to positive and negative, depending upon which end was which.
HTH
Mike
Thanks for your replies!
Found an article that others might also find useful. http://sound.westhost.com/pots.htm
With regards to the faders with 4 pins and two of them being labelled pin 2… do i connect them to each other?
Check with a testmeter - they are usually already connected.
Mike
