Does MBFM work ok with 18F4685 or am I better sticking with original 18F452?
I intend building with full control surface and 8 bank sticks, guess there’s no advantage in using 24LC512 rather than 24LC256?
Thx in advance,
Allan
Thx in advance,
Allan
Yes, it should also work on a PIC18F4685, although I never tried it.
A 24LC512 doesn’t give you any advantage, because only the lower 32k range is used.
Many thanks for the fast reply Thorsten, I’ll go with PIC18F4685 and get the parts ordered up now.
Another MBFM will be added to the ranks soon ![]()
Cheers,
Allan
you probably need to treat the pic as if it were a pic18f452, as i’ve described here:
