Hello all,
I read through a bunch of documentation and source files, but somehow cannot figure it out:
I want to use three 2x16 character LCDs, so I understand I need to include the clcd_multi driver and I can use any free PIC pins for the enable lines. Since I am using analog inputs (not multiplexed) and no motorfaders it seems to me that RC1, RC2 and RC3 might be good cancidates.
What I cannot figure out is which file do I need to edit to tell the driver which pins to use?
Also, when using this driver, what happens with the standard LCD available in Mios? Is that disabled then?
Many thanks for your guidance!
Reiner
Hi Reiner,
It’s in the app_lcd.inc file
#ifndef USER_LCD_NUM_ENABLE_LINES
#define USER_LCD_NUM_ENABLE_LINES 8
#endif
#ifndef USER_LCD_LAT_E0
USER_LCD_LAT_E0 EQU LATD ; Pin D.7
#endif
#ifndef USER_LCD_PIN_E0
USER_LCD_PIN_E0 EQU 7
#endif
#ifndef USER_LCD_LAT_E1
USER_LCD_LAT_E1 EQU LATC ; Pin C.5
#endif
#ifndef USER_LCD_PIN_E1
USER_LCD_PIN_E1 EQU 5
#endif
#ifndef USER_LCD_LAT_E2
USER_LCD_LAT_E2 EQU LATC ; Pin C.4
#endif
#ifndef USER_LCD_PIN_E2
USER_LCD_PIN_E2 EQU 4
#endif
I suppose you have to change the number of LCD from 8 to 3
Then change PORT and PIN for the 3 first lines E0 to E2.
I never tried it so I don’t know, but I think the first one is selected at startup, so first lcd should work normally.
In your app you have to use USER_LCD_Select to select another LCD.
More information are in the READMEfile
Have a good day!
Bruno
Thanks Bruno,
that looks pretty clear now!
I’ll try it out int he next couple of days and report back.
best regards
Reiner
