I’m testing my MBFM and I can play the E-Piano, but I can hear only the kick (when pressing the note C2, maybe octave 2, I don’t remember)… it’s normal or there is to do some tweaking?
The preset (which is stored in internal EEPROM) should have all instruments pre-assigned to individual notes.
I don’t remember them exactly… but you could use the JSynthLib based MBFM editor to visualize (and change) them. You can also change them on the Control Surface (if already available)
drums found! the original setup isn’t very intuitive, i had to modify it via jsithlib but now everything works.
i’ve noticed some troubles using midi yoke, midi ox and jsinthlib.
when using jsynth with the hardware midi port everything works fine, but when using it via midi yoke and when getting a patch from the MBFM it receive about 270 bytes and freezes here, the patch doesn’t appear in the patch list. i’ve noticed that when using hardware port the jsinth receives less bytes. i suppose i have a config error, anyone had a similar problem?
