I have taken a look at the wiki and seen what i need to buy in order to get a working midibox - but when i go to http://www.midibox-shop.com/buy.html to get parts, they have different names, than the one on the wiki (core8 etc).
What do i need to buy if i want to do this:
a midi controller with 6 switchpots (6 steps each), and 22 pots -normal ones, not encoders. and 11-20 switches with 2 steps/settings (basic on/off).
It only has to have midi out. i have no use for an LCD - basically this is for controlling the creamware minimax synth (located on my computer/dsp cards) - its a minimoog clone.
You might want to look into getting a 2x16 LCD for debugging and display purposes while developing. Suppose for instance that you may want to store a few presets of what the controllers do, MIDI channel setup for your controller etc. It’s only a few euro/dollars/pounds.
Your “switchpots” are rotary switches. Look at getting some Lorlin CK-series rotary switches (1pin per pos), or get some Grayhill mechanical encoders like the 25LB22 (16pos) if you rather need an easy (few pins) binary interface. The Lorlins are usually 12-pos, but you can set the number of stops yourself to suit.
