I was wondering what PC soundcard you guys were using… I personally have a cheap sblive 5.1 and getting quite fed up with it (and with Creative Labs in general)
I want a card that supports 5.1 DTS and that has ASIO capacibility…
the terratec has good quality sound and plenty of features + ASIO2 drivers t work nicely with all software although this may have been fixed with their newer cards.
Many people complain about the audigy but I find it an excellent all round card it has ASIO drivers with reasonable performance and very compatible!
I’m using a cheap soundcard based in the C-Media 8738 chip.
Don’t laugh. Here is the trick. It has S/PDIF I/O on co-ax and optical. I have connected the co-ax I/O to my old Roland S-770 samples which happens to have Apogee ADC and DAC. This way I’ve got top quality conversion for less than $60 NZ (I picked up the sampler for $250 NZ a couple of years ago, this machine was brought by the original owner for $15 000 NZ !!! in 1989).
I think this is a good option for those of us who have been in the game long enough to have a sampler or the like taking up rack space and not getting used.
Only problem is latency, I’ve got it down to 20mS with Direct X 9 and ASIO > Direct X driver within Cubase SX.
I’m runnin a Pulsar2 on the main logic DAW, and have a turtlebeach montega (it was gratis;p) in a 2nd comp - used to handle all MIDI i/o routing (MIDIoverLAN sends it to the logic DAW), also got vstack installed to handle a couple of vsti’s (controlled in logic via MIDI as regular synths)…
I am using a RME Hammerfall (The best audio card you can get) on my main music computer (running Cubase SX under WinXP) and a Pulsar I on my secondary computer (running V-Stack on Win98SE).
working all well exept the “normal” problems with VIA chipsets and audio, but i’ll get a new mainboard soon
I agree with Mr.Musicman that the RME cards are the best ones you can get, for a short time I also owned a Hammerfall with a nice ADI 8 AE AD/DA Converter running under Win98. IT ROCKED!!! Never heard clearer sounds before or after having that card.
But I think it was a bit too professional and expensive for me. I sold it (for a better price than I had actually bought it ) and got my M-audio card.
I have KX drivers currently installed on my sblive 5.1 problem is, the SR is locked at 48KHz for some reason and my main audio app (audiomulch) is not (yet) compatible with this SR (must use “standard” 44khz)
So this is why I am looking for a new card atm…
What are those ASPlive drivers that were mentionned?
Some years ago I had a lot of different sound cards in my PC at the same time (e.g. a Gravis Ultrasound, AWE32, SB Live and XG compatible), not at least to get as much MIDI ports as possible But in the meantime I also switched to RME Hammerfall DSP (+Multiface) - no driver & latency issues anymore + 8 analog IOs for realtime processing + support for Linux. For me this card + the PC software are a replacement for the even more expensive Fx gear
Yamaha DSP Factory over here, still a great card, bought second hand it can be quite a bargain :-).
Only thing negative about it (about me, eventually?) was that I am too dumb to use it with Logic, so I switched to Cubase some time ago. There the integration of the card is quite well done (if you don’t care about yesterday’s graphical appearance of the mixer representation…)
