What kind of buttons for menu?
Hi, I was wondering what type of button is recommended for the menu in the minimal build for the SID. I assume these are momentary button switches correct? How do these look:
http://cgi.ebay.com/10-LOT-6mm-TACT-TACTILE-PUSHBUTTON-SWITCH-SWITCHES-SMD_W0QQitemZ230016354688QQihZ013QQcategoryZ58166QQtcZphotoQQcmdZViewItem
What do they mean by tactile? Maybe they are too small?
those are surface mount tacts, so you don’t want those ones, plus you probably want ones with a bit of a stalk on them so you can put keycaps on then.
tacts means you feel a click when you press it, your mobile phone probably has them on the menu keys and on the send and end call buttons.
have a look through the forums, there is more info on buttons than you can poke a stick at
