I owned my 2nd Midistart2-Masterkeyboard and plugged it to my PC with normal Midiconnection (not USB)
Then I plugged a walltransformator with 9V/500mA, it works great…after a little time I plugged off the PSU and noticed, that the power LED is still on…
ok I thinked and grabbed the keys and it sends also NoteOns/Offs…I was more surprised when I switched Off the Power-Button and the keyboard works also :o
My evolution MK-7 mini keyboard does the same, it plugs into the PC joystick/midi port. I think it uses the joystick power common on the soundblaster input plug.
As a thought, I’ve just worked up a design for a stand alone box for it - so it will work as a midi keyboard without being plugged into the PC. Is it worth putting on this on line ?
As above, it’s probably working off the +5v line coming from the MIDI connection. The power button would be connected to the external inputs, so the MIDI power wouldn’t be affected by it.
You know, stryd, if you added an emulated joystick port to the MBMK that would make a load of cheap keyboards (and four pots) useable. Same goes for a USB Host IC …
This one’s nice, it has two high speed USB ports, software switchable to Host or Slave. It even has PS2 ports.
