what is the best Anaolg Out solution for Sequenzer
Hello,
i would like to upgrade the sequenzer with analog out…
i have seen the LC Module wich i could get at mikes page
is easy… what are the diffrence between all those analog outs?
can i just controll normaly my doepfer or any other modular Synth
with the LC?
thanks for any answer  8)
i’ve been looking into the cv out a bit too for my seq.  all the info is at ucapps.
If you are only wanting to control VCF’s and VCA’s then the Aout_LC would be fine, however if you are controlling VCO’s then zipper noise and resolution may be a problem. You could always run CV output through Doepfer slew module first with a fast slew setting and this would help.
My choice would be the Aout _NG, nice quality dac and 8 cv outs (rather than 2cv outs on the Aout_LC), which means you could have independent control of 8 CV Voltages from the MB Sequencer - for example you could control VCO pitch, VCA level, VCF req and VCF resonance all at the same time and still have 4 CV outs spare.
Just my 2cents worth  8)
Allan
thank you
