What happens if my powersupply doesn’t give enough mA?
I have a 9VDC/500mA and I’m starting to wonder if that’s enough to run everything on the SEQ, with the two backlit 40x2 LCD etc… Should I start off with the pot for the LCD lighting all the way off and work up from there or what?
Am I running a risk of irritating (permanently) the PIC or LCD controllers or anything like that?
I think that doc would be better to answer this, but anyway:
If your regulator can’t supply enough power to the circuit, it overheats - and thermal protection kicks in, it starts to limit current, by droping output voltage. (remember your U/R=I)
This probably leads to strange behaviour, random resets ect.
If your transformer is underrated, then everything might seem like normal, as regulator can suck enough power out of it anyway, BUT transformer heats up, let’s say more than in normal use.. (Or it might even have a fuse that blows.. but usually no thermal protection.)
This shortens expected “life” of the transformer and in extreme cases can lead to fire hazard..
