What Do I need?
Hi folks!
I just finished my first Midibox 16 and it works fine!
But I am already planning something bigger - a modified Midibox 64. Here you can see what I am going to do:
As you can see there are 64 pots, 54 buttons (channel buttons plus the small red ones, and the two green ones), and 12 LEDs (above the channel buttons). My question is - what modules do I need for this nice little mixer and which Pic Controller might be the right one?
Are these schematics I made correct? I don´t want a COM interface, Midi In and Out is enough.
Last question, what is the bankstick module good for?
Well, I hope you can help me - thanks in advance all you guys!
Regards,
Iwen
Looks good to me!
The bankstick will let you save different setups. i.e. Pot assignments. If you are always going to use the same setup, youw wouldn’t need one.
I would recommend you build it with the new 18f. There is already a firmware that handles 64 pots, 128 buttons and 128 led’s.
Justin
