just to add some info: you can always mix encoders and digital switches on one DIN board, you just need to follow the appropriate order. also you might have to make changes in your firmware setup file. what you can’t mix obviously are switches or encoders with analog pots, that’s all.
while you’re at it you could consider also getting a small bank stick pcb for 8 eeproms (you can get the board also from mike, not sure if they’re listed in the shop though)
pleas show some pics of the process, especially the HD jogwheels!
edit: here’s a link (as example for combination of switches and encoders), it’s of the sequencer, but basically the same thing:
Or are there functions in the MIOS Studio 2.2.1 software that allow me to do that once paired with the PIC (I ordered it today so i haven´t got it yet).
Thank you!
PS: I really like to figure out new stuff but the access to the stuff shown in the link i posted above is really challenging.
maybe an already finished project is right for you - have a look at the MBHP projects section on ucapps.de and in the user projects section in the Wiki.
If you don´t find anything that suits your needs, I would recommend to directly jump to MIOS32 (and replace that Core8 by a Core32) - it is easier to program and has very good tutorials here:
