after the troubles i posted under the topic “problem with mb tiny control”. i reprogrammed the pics (two of them 18f). and now: NOTHING works!!! :'(
everytime i programmed them and put them onto one of my core boards (three pieces) and connected one of my two lcd-displays (202a from reichelt) i only get the upper line filled with rectangles… nothing more ??? ???
the bootstrap-loader is burned correct (verified by ic-prog) and sends his midi-message. even the upload of mios v1.2 works fine (id 0f xx f7) is sent after every block.
what could be the error??? did somebody have the same problem? i checked all topics depending the same error but reprogramming the pics didn’t work and the contrast-pot isn’t broken too…
it’s really weird: i soldered the display just like you’ve shown in the picture. first i thought there could be another pin-assignment at this display but the data-sheet shows that it’s the same assignment as in the example. i checked the wiring approx. 20-times (for each of the two displays).
there’s no cause for that i can imagine. and the very first time i plugged a display to one of the cires all worked well except the mios-upload. and after i re-programmed the pic this weird solid line was displayed. ??? ??? ???
ok, now i’ll go to bed and hopefully tomorrow i’ll find the error (don’t know where to search anymore but i’ve got a good feeling… :-/).
I did some research on the net, it appears the first lcd I bought wasn’t compatable ! :
The second lcd was compatable, and after wriggling the ribbon cable the display fired up with MIOS 1.2, it appears I had a broken wire somewhere in the cable.
