It has most of the functionality of the Discovery one, but has a few improvements:
USB ports are on the breakout, so there’s proper USB B
USB A “host” - still need to test this, but it’s normally done setting the ID pin low. I’ve put a panel switch for selecting host/slave and there’s a jumper to power the slaved device if needed.
LEDs and reset button on the panel; “blue button” as a jumper
a 3.5mm socket for a footswitch or gate (or for other purposes)
some connectors for +5V supply direct off the USB bus
3v3 Vreg is rated at 1000mA I think
the panel connectors could be distant from the Core
I haven’t tested the AINs, but it is possible to use an external reference.
At the moment I have the breakout mounted on female headers; I suppose they could be directly soldered if extra height is needed. The JTAG and other pin headers do take up a bit of vertical height. These could be cut off if needed; the breakout pins are still there on the headers. There is a realtime clock oscillator (and caps) that I removed as they overlapped with a port.
A downside compared to Discovery is that there isn’t any ST-Link. This is easily overcome with a cheap ST-link clone, or even an old Discovery board could be used.
At least all of the functions for a SEQ are working well. I realise that some of the cabling etc. is a bit wonky for the moment.
So even a bit higher than the Disco version with the bottom headers; about the same without. There’s not much reason to keep the panel board close to the Core, although I will do it like that for the SEQ and everything aligns nicely. I suppose the signal integrity (USB, SD) is better with shorter cables.
The panel connectors are themselves quite high. Honestly, I think the only way to do it shorter height-wise would be with a dedicated STM32F4 chip on a custom PCB. With a breakout it’s fairly much plug-and-play, and probably cheaper.
I did one but never manufacture the board then never test it. It’s a good way to gain space, the board is really small, but if you’re not afraid about small smd components.
I have to remember exactly which package I use, but same CPU, there’s exactly the same port as usual, except J11 which is a 6 midi ports and USB, two tact, micro-SD on board.
I can share if you want it…
Bruno, looks nice! Your offer is kind, but I think it will be okay with what I have. In my experience, builders have quite some trouble even with SOIC parts, so I try to go no smaller than SOIC/1206/SOT-23. And of course THT parts when possible as they make nice jumpers!
I think the Waveshare paradigm is a good one to follow as they do a lot of STM chips:
Yannick, I need some weeks at least to talk with the Bavarians. I also have to prioritise giving boards out to those interested in the SEQ. But hopefully more becomes clear soon.
Yes i know that’s one of the reason i didn’t share it, some soldering experience and a lot of flux paste is necessary, obviously some good equipment and tool too.
