Wanted! Man building SID chip substitutes.
A while back i found a page containing info “how-to-build” a SID chip.
This was a substitute SID chip based on two PIC’s i think…
I don’t remember the name or the name, so it’s very hard to google it..
anyone here know what im talking about?
SwinSID?
http://www.midibox.org/forum/index.php/topic,10531.0.html
http://www.midibox.org/forum/index.php/topic,9386.0.html
I could kiss you!
Is the SwinSID page removed?!?!?
http://www.swinkels.tvtom.pl/swinsid/
<edit>
A friend of mine wanted to try to build a SwinSID now that im working on my MbSID,
but i’ts gonna be hard without documentations and schematics  :-\
AFAIK the version 2 documentation is just about to be uploaded, so that might be the reason for the page being offline.
Ah, thanx nILS!  :-*
you mean “advanced sid substitute,” right?
The patent for the sid chip has expired right?
I wonder how much it would cost to go to the likes of Taiwan Semiconducters and remake a few 1000 sid chips, or whatever the minimum production amount is?
Totally out of curiousity!
I wonder how much it would cost to go to the likes of Taiwan Semiconducters and remake the a few 1000 of these chips, or whatever the minimum production is?
TOO much.  with wilba and the 6582’s the only SID “remakes” i’d be interested in are 6581’s.  i love the raw, distorted filter… call me crazy. :stuck_out_tongue:
wow! i love when i recieve a reply that quickly! clicked refresh and bam!
Of course bugfight!
Anything else would be rude.  8)
Together we ordered a smaller batch of TDA1543 DIP’s from Voti.
Gotta find the ATmel’s to now..
Finding the AVR’s seem a bit harder then the DAC’s.
surely the right discrete components splattered onto a pcb SMT tech style would get awfully close (and would be affordable) ? :wink:
I see…
..Would you care to elaborate?
how such a thing could be made out of really small discrete components & assembled in a batch by machine:
http://en.wikipedia.org/wiki/Surface-mount_technology
how we assemble things manually here:
http://en.wikipedia.org/wiki/Through-hole_technology
Are these the right AVR’s?
ATmega8515
you do realize mind that a simulation of the sid chip based around some digital technology wont actually provide the quirks of the real analog sid sound, ie: what makes it interesting.
may as well hunt down one of the vst plugins ..quadrasid if i recall; at worst the hardware mentioned here wont hold an advantage over it ..and if i do remember right ..and they did actually model the filter behavior (etc) properly in the vst ,then it should be the nearest thing to a sid chip without having one :slight_smile:
I disagree. What makes it interesting to me is that it’s price:features ratio is low, low, low, and it’s hardware so I don’t have to deal with crappy vst’s. If someone does up a chip that has more power for <= money I’ll be very interested.
fair do’s ..will sit back and watch out of curiousity :slight_smile:
mind quadrasid from refx is $59.99 usd / 37 uk pounds or so …its not steinberg money :wink: ..and from my experience its not crappy unstable either.. and you can have as many virtual chips as you wish.. whereas more chips means building more with this hardware ..and both are doing the same thing of running some code, on some hardware.
http://refx.com/?lang=en&page=products/quadraSID/summary
sample sounds:
http://refx.com/downloads/quadraSID/quadraSID.mp3
mind i guess its worthwhile as hardware if its moved upto a serious dsp powerhouse; where the architecture can support tens, to hundreds of sids …but then you are creeping towards making something that strictly isnt a sid ..and may as well diversify way beyond its limitations ..in which case its no longer a ‘sid’ at all.
Maybe it’s just me/my setup or whatever but quadraSID crashes the hell outta my Cubase on a regular basis. I alsways had problem with patch saving as well, as the VSTi seems to reset at random times.
I do realize that emulating the SID will never make it SID.
But thats not why im building it.
  1. Building is fun
  2. It can emulate SID
  3. It’s cheap
  4. It has more waveforms
  5. Building cheap stuff with more waveforms is FUN  ;D
Same here.
What version of Cubase are you using?
