Hello!
This is my first post, rilly excited!
I’m approaching finishedness of my sweet Sammich and I’m having some questions popping up.
First, not such a big deal, is the LCD display.
There are some details about how to put the jumpers depending om what kind of lighting the display has ( edge lit vs LED array).
However, I can’t for the life of me make out any indication as to what kind mine is!
The only hint as to what it might be is on the front, where there’s a small “5V” in between the display and the encoder.
Oh well, I set the jumper config to the 25mA settings to play safe and I seem to get the screen to start up after doing voltage tests and plugging it in.
Now to my main problem..
Seeing as the manual strictly states to Never use 6581’s (R4, which mine are) with the JP set to 6581 (which I have) with an unregulated PSU..
Well, I thought I got a regulated one from the store.
It’s an adjustable one, and measuring it up produces some strange results.
It’s supposed to be 1000mA regulated PSU.
Measuring the current gives me results sligthly below 3(!) Amps.
Also, the output voltage (unloaded) set to 12V gives me around 14.5 V.
Plugged into the unit (without the SID-s installed) gives me slightly lower results.
The 9V setting produces about 11.9V unloaded.
I’m unsure of the brand, but I got it from here:
http://www.electrokit.com/batterieliminator-1-512v-1000ma-stab.49112
Thanks for a great community and a beautiful product!
Regards
/M
