vmidibox64E
Has anyone had any issues with vmidibox64E storing syx  files to disk? Whatever I try I am unable to save anything - nothing is changed within the syx file from default settings. vmidibox64 is working great. I’ve tried running vmidibox64e on both XP and Vista with the same effect. Is this a known issue or have I overlooked something?
Cheers peeps.
My bad. I just checked and nothing I changed on vmidibox 64 saved either  :frowning:
Does anyone know if this is a problem I am having or is it just here?
If you rename the existing syx file does it make a new one with different contents?
No I tried that. A new file is saved but nothing changes in the contents. I have also tried win98 compatability mode but still does not save. If I change bank name and save and then open syx in notepad the bank name is not changed in the syx.
