vj mixer
hey up
i just wondered if anybody made a controller for video mixing ive started using resolume and i want to make a controller to use with it
with Jitter (a Max/MSP derivitive) you can control video with any controller you want. midi devices included.
might want to check it out.
hi,
almost every parameter in resolume can be controlled via midi. so it should be no problem.. just take your favourite mios-application and build a nice frontpanel.
(do vjs use step-sequencer for modulation? i think it would be cool for example to jump to different frames via stepsequencer :slight_smile:
g. tz
thanx
the step sequencer idea is good
im designing a layout for reasolume at the moment
but ive not used it much so got to keep practicing before i get the ideal  lay out so thats why i wondered if any body had done something already
thanx kris
i use resolume as well, and im planning to make a midi controller at the end of the year. resolume just uses any midi device, so its more of what layout you want… make it… and it should work rather easily. there is a resolume specific controller being made atm, for sale… not using MIOS. but there are pictures of the design of it http://www.resolume.com/react/index.php
