Hello, does anyone know where to find a 2x10 vfd bargraph (1x10 ok too)?
Thanks in advance
Thanks in advance
… why don’t make one out of a single line character vfd?
http://www.parallax.com/images/robotics/machining/rpm_display/avi/RPMDisplay.AVI
Greets, Roger
I thought about it, but since I designed the circuit with an LM3915 to monitor on logarithmic scale audio signals amplitude, I don’t know how to implement it to a normal VFD. Have you got some clues on how to do it (LM3915 can drive up to 10 leds, more than 10 would be really appreciated
Maybe using another IC?
Have you got some clues on how to do it (LM3915 can drive up to 10 leds, more than 10 would be really appreciated Maybe using another IC?
I have no experience with VDFs but you can cascade two LM3915 for up to 20 LEDs. Look at the datasheet:
http://www.national.com/ds.cgi/LM/LM3915.pdf
Raphael
Thanks raphael, the question is: the datasheet shows how to interface the lm3915 to VFD bargraph.
normal VFD’s (I’m used only to noritake U-series so same interface as HD44780) offer same pinning of standard hd44780 lcd’s. there are not as many pin as character number on display, that’s because I don’t know how to interface the LM3915 to a VFD
I forgot: the best deal would be to use one vfd 2x16 to monitor a stereo signal
