I made a TB-303 Clone and try to use my MIDIbox 64 as sequencer. My clone uses velocity to control the accent, so i have to control - note - velocity and note length with my MIDIbox. Is this possible?
I could control the note and the gate but not the velocity.
you can control note, velocity and gate at the same time with the 3 upper pot tracks in all modes beside of “independent mode” - best results in “transpose hold” and “arpeggiator hold” mode.
Yees, thank you. I tried i just in independent mode. Â : But there is still a little problem. My tb plays a slide when i note is legato. The Slide Led is flashing on every note, it doesn’t matter how short a note is. I tried this in combined mode. Is the MIDIbox playing every not legato? Is this possible?
I made the one from LosDos Germany. Yes i’m very happy with it. I have an original to compare and they sound 99% the same. The schematic is exactly the same as the original. I think the difference exactable. The pcb was not the best and he used a 80C31 and an eeprom for the midi interface witch is a bit oversized and to expensive i think.
