Velocity-Curve-Controller
Hello,
I’m absolute new to MIDIbox. Found this page while searching a solution for my problem:
I would like to build/program a device that should do only one thing: changing the velocity curve of my masterkeyboard, adjustable for every single key. I want to achieve a better feeling for playing digital piano. What I mean is: every “NOTE ON” event received should get a translated velocity-value and sent out via MIDI again.
My short question is:
  • is MIDIbox the right (Hardware-)starting Point, will it have enough power to do this without producing to much delay ?
  • which board should i choose ? I only need 2x MIDI in and 2x MIDI out (of course it can be more !)
Thank you,
Matthias
Yes, MIDIbox is the right platform for this type of application. You could either program this yourself from scratch, e.g. using a set of look-up tables, or base your application on the MB-NG framework. As hardware platform I would recommend the most recent core board, i.e. the STM32F4 based core.
Thank you,
I will try this.
