V2 sysex?
Hi… this is basicaly for Thorsten:
I’ve finaly made a V2 SID synth here, but as I’ve not build any control surface I’m set on doing a Sound Diver editor for the V2 engine… I’ve not been able to find any kind of SysX info on the V2 engine horsten… is this because it does not support this yet, or won’t at all?
Without SysX capability it’s kind of hard to store patches on a surfaceless version of the V2 engine…
You need this? It´s in the MB-SID ZIP File under DOC.
A sounddiver PlugIn was a good idea :slight_smile:
[mbsidv2_sysex_implementation.txt](< base_url >/applications/core/interface/file/attachment.php?id=910)
[mbsidv2_parameter_chart.txt](< base_url >/applications/core/interface/file/attachment.php?id=911)
[mbsidv2_sysex_implementation.txt](< base_url >/applications/core/interface/file/attachment.php?id=4052)
[mbsidv2_parameter_chart.txt](< base_url >/applications/core/interface/file/attachment.php?id=4053)
I’m uncertain of this… the only thing I’ve found seem to be sysx ifo on MIOS itself, and not the MB SID V2 specifics… I need to know patch request and patch dump strings etc… if any is there at all… I’ve found for the V1 enginge, but none for the V2 yet…
Pascal:
Just saw the links to the files you gave… thanx!  :smiley:
Hi Razmo! :slight_smile:
Please note, that the most current version (with corrections, etc…) can always be found here:
http://svnmios.midibox.org/trunk/apps/synthesizers/midibox_sid_v2/doc/
