It is my understanding that I can plug a USB keyboard directly into the SEQ to control transposition, Arp, CV outs, etc…
Since the USB keyboard is powered by USB, I would assume that I need to bridge Pin PA9 to 5V in order to give the USB Keyboard power via the micro USB. Is this correct?
I am using my own MeanWell 5V power to power the SEQ. Is there any issue if I bridge the pin and then connect the seq to a PC via USB? I am worried that I could fry something if I use my own power supply and then plug the micro usb port into my PC.
I fitted a switch and a USB connector to the SeqV4 case to put the SeqV4 into USB host mode. The switch jumps R59 on the Discovery board to ground, then you can use a USB keyboard controller, which then receives power from the SeqV4. For firmware updates I power down, unplug the power supply, switch USB modes and connect the PC. I don’t know what PA9 does but that might be a better way to simulate what is basically an OTG USB cable
