Hi
Is it possible to integrate the led matrix driver (from sidmatrix test)
with the C scanmatrix example?
I want to drive 64 leds and 32 buttons using a DINX1 and a DOUTX2
Michaël
Hi
Michaël
You might find some helpful clues linked from the DrumStuff wiki page.
I allready looked at that page but none of the links provide the combination of buttons and leds
(correct me if I’m wrong ???)
in the meantime I’ve build the button/led matrix with two DOUT registers for the leds
and seperate DIN/DOUT registers for the button matrix (driven by sm_example code)
so I just have to modify the SID ledmatrix example and
add a C style header for the asm functions…
I’ve managed to get this to work ![]()
I’m using one dout to drive both matrices
and a din/dout for buttons/leds
modifications to scan matrix example:
in main.c:
//second shiftregister drives the leds
#define LEDOUT 1
void LM_SetRow(){
MIOS_DOUT_SRSet(LEDOUT,ledtest[sm_col]);
// This function is called by MIOS before the shift register are loaded
void SR_Service_Prepare(void) __wparam
// call the Scan Matrix Driver
SM_PrepareCol();
// call the Led Matrix Driver
LM_SetRow();
in sm_simple.asm:
global _sm_button_column
global _sm_button_row
global _sm_button_value
global _sm_col
;; import lables
extern _SM_NotifyToggle
accessram udata ; (no access ram required, these variables can be located anywhere)
_sm_button_column res 1 ; exported to C, therefore an "_" has been added
_sm_button_row res 1
_sm_button_value res 1
_sm_col res 1
SM_PrepareCol
;; select next DOUT register
;; (current column + 1) & 0x07
SET_BSR sm_selected_column
incf sm_selected_column, W, BANKED ; (* see note below)
andlw 0x07
;_sm_col is used by LM_SetRow()
movwf _sm_col
call MIOS_HLP_GetBitANDMask ; (inverted 1 of 8 code)
and finally in sm_simple.h:
extern unsigned char sm_button_value;
extern unsigned char sm_col;
I don’t think this is the most efficient way to do this
but it works for me ![]()
Michaël
Well done mess :D I’m adding a link to here from the Drumstuff page.
What project are you building this into?
ever since I saw the clockbox example I wanted to build a drum seq
so it’s gonna be a drumseq ![]()
you can read some information on my first attempt here:
http://www.midibox.org/forum/index.php?topic=6980.msg45082#msg45082
the new design is based on some of the suggestions
in the “when will come the trseq” thread
feature list:
32 step 8 track drum seq, each step has trig/acc/roll
16 patterns, will be expanded when seq is up and running
patterns are saved on a bankstick
simple UI:
lcd: displaying [bpm pat trknr (edited par)]
32 step buttons + stepleds, leds are dual color to display trig/acc
all functions are accessed with a stepkey + shift combination
pattern selection: stepkey + pattern button
track select/mute: stepkey + track button
rotary encoder for modifying parameters
some pics of the seq:
picture to show the size (it’s reeaally compact ;D)
matrix wiring mess:
looks good.. very nice!
Nice work!
I’ve started a wiki page about the seq:
http://www.midibox.org/dokuwiki/doku.php?id=dseq32
page is still under construction ![]()
Michaël
