Hey!
General question: Is it possible to use other LCDs than thought to? I used a 16x4 on my 16F MB64 and now with the port to MIOS (18F) I’m just using two of those four lines… Is it somehow possible to redesign the Display? Also in other apps?
Hey!
you can always add your modifications, the top-layer of the display output routines can mostly be found in cs_m_display.inc
Check the current MB64 application where Duggle has added a new display mode for 20x4 displays - thats the way how you can do it also for your stuff
Cool, thnx!
OK, I’m on it. Check your email for more. :D
why don’t you post your mod here or on the portal??
Cause its likely to be implemented in the next release. ;D
And cause its still be some time until its finished (getting into the depths of MIOS takes its time… ;)).
