Using a touch switch with Midout
I’m getting a little confused, (not unusual).8-))
I read that you could use a couple of contacts, such as drawing pins to form a touch switch on an organ stop tab using the Mido module.
Is this correct and how are the modules wired together?
I guess that one touch would turn the tab and an LED on and another touch would turn them off?
Is there a wiring diagram I can see to confirm this please?
Thanks,
Arnak
Welcome aboard Arnak!
http://www.midibox.org/forum/index.php?topic=9220.0
This thread had a discussion on touch sensors.
http://www.ucapps.de/mbhp/mbhp_din_touchsensors.pdf
This is a link to the wiring diagram you seek.
Have fun!
Thanks for the welcome.
Great, thanks for that, the thread looks interesting.
The only problem I can see is that the thread mentioned that no one had really had a lot of success with the inbuilt touch switches, so it appears to be an area open fore experimentation?
Arnak
The MidiBox_LC application makes use of the touch-sensor function, perhaps that would be a good place to look.
Hi Tilted,
Thanks I’ll take look.
Arnak
