I want to use the LCD display to show disply status messages from the Hauptwerk organ program. Looking at the MIOS-sysex implementation I found that MIOS should be able to show information on the LCD when the correct sysex-messages are sent. This sounded good, so I went ahead and got an LCD for my Midio128, which I use to set stops from my console.
I am very happy to report that the display works, thanks to you all for the good instructions! My problem:
Apparently Midio128 also makes use of the display (showing each button press and incoming message). And the display does not show anything when I send the sysex message to the core, so I guess the MIOS display function is disbaled by the midio128 application.
Is this so?
So I will have to adapt the midio128 application?
best wishes
Reiner
