usb
hey up thorsten
i remember there being a lot of disscusion about usb
did anyone do it or did everyone go serial
If I am right the only problem with the usb is that is very difficult to get the chips required in low quantities therefore imposible for diy applications.
A nice convertion is to buy a usb to serial cable for around 15 euros. the only drawback is that you will have to install the drivers for both the cable and the serial :frowning:
Yes - unfortunately the statement I made in this old posting:
http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=old_forum;action=display;num=10308161100;start=2
are still valid. My still hope is that some day ultracheap USB devices are available (for example an USB-Mouse for less than 10 EUR) with an reprogrammable chip which can be canibalized for a MIDI adapter.
Hi All,
Take a look at Delcom at http://www.delcom-eng.com/ for an inexpensive USB chip at aroun 8.00 USD. (They also have a development board also for about 49.00 USD.) Schematics and data sheets are available on the site. I have not tried the chip yet, but I got interested when someone on another list had written MAC OS X drivers for the Delcom chip.
Later,
Mickey
Hi Mickey,
unfortunately this is a preprogrammed ROM chip which is useless for MIDI. It’s a pity that they don’t offer the AN2131 of Cypress, because this derivative comes with a bootstrap loader - this special mechanism is activated when the USB cable is plugged in and allows to load the right descriptors and some additional code into the memory so that the device will be recognized as “Standard MIDI-USB device” by Windows, Mac OS X, Linux… without an selfwritten MIDI driver.
P.S.: the AN2131 has 2 UARTs (=2 MIDI INs & 2 MIDI OUTs) and costs about US $3 — but w/ a minimum purchase quantity of 1k devices :-/
check the chip from texas instruments tusb3410,CAN PERFORM USB TO RS232 AND IS PROGRAMMABLE,interesting chip… :slight_smile:
Guys,
Call TI EPIC:
http://www-k.ext.ti.com/sc/technical-support/pic/euro.htm
Tell them that you’d like some samples for development of a new project. If they ask you what your quanitity is, tell them less than 20 per year. They should still send you the samples (up to 10) but not hassle you with sales guys.
Good Luck
R
…but it’s only available in a SMD package :-/
thanks for all your replies the serial to usb cable seems to be the best option sorry i dont reply so often but im in india at the moment
never be scared of [glow=red,2,300]SMD[/glow]… you just need a steady hand :slight_smile:
When desinging the PCB, allow a little more distance for the pads your soldering to.
Found this site for company in japan:
http://www.ipishop.com/usb.html
They sell the AN2131SC for 1,200 YEN which is about 9EU and I believe there is NO minium order…:wink:
HTH
Hi i am new here ,but really intrested in what it is happening,
i found this info about the EZ bus AN2131, i think it could be usefull
http://csx.jp/~fex/ezusb/buy-en.html
it is only for Japan  but  it is intresting
from argentina
                           Jonisio
8)[glow=red,2,300]TEXT[/glow]
hi again , i found an AN2131 inside my midisport 2x2 and an CY7C63413PVC inside an Imate i do not use ,usb to ADB from Griffin can you tell me if it is usefull?
thanks
     gracias
                Jonisio ;D ;D
Problem is, that all development and/or premade boards for this SMD (=hard to solder) chip are more expensive than a ready-made USB MIDI interface, so that you cannot really save money.
Now almost 16 years later, there are enough videos on Youtube showing how to handle SMD.
The problem is not only the low price of ready-made USB MIDI interface, but the need of open source firmware to study when you want to develop on the same microcontroller core, to build your OWN hardware with several ports and other I/O like digital audio, buttons, knobs, faders, displays, lasers, blinkenlights…
The bigger AN2131QC had a parallel bus interface, if one wants to add two more MIDI ports with a dual UART like the TL16C752C, and can even run from external Flash (3.3V, and this requires the knowledge to make a bootloader to program it), but it looks too obsolete and hard to find cheap as new old stock, so if one likes coding in 8051 assembler and does not feel like switching to 32-bit ARM, it seems better to try its USB2.0 successor, the FX2LP CY7C68013A-128AXC.
