I made the usb module and to my surprise when I plugged in the usb cable XP recognised it as the cypress usb and I then installed then drivers…
Loaded EZ-USB control panel and followed the instructions in the txt file - I got the 000F msgs as described. However, on completing the eeprom upload and closing ez-usb cp, then unpluggin and pluggin back in the usb cable nothing else happened XP didnt recognise nething new…
Any ideas?
Dan
BTW: I used 24ohm inpace of the 20ohm resistors - this okay
HOLD THE PHONE!!
Well, i just hit pot luck here…
Uninstalled the cypress driver frm the 1.1 rls, installed the drv from the V1 rls, and just hit eeprom and opened the mbhp_usb.HEX file…XP rcognised a new USB devices instantly!! I checked midi-ox and I have 2 new ports labelled as USB Audio Device 1 and USB Audio Device 2!!
BTW. I think it’s possible to change the names of any ports (sound/midi) via regedit. just search the name as it stands and modify the binary data…just done a clean install so I aint gonna get dirty in the reg just yet tho
Hmmmmm, that didnt last too long…just unplugged the module to get it boxed etc, plugged it back in and nothing wasnt recognised even loading the firmware as I did before didnt cure it…
Ah well, it’d wudnt be right it working first time
Dan
Did you reboot? several of my machines here (both PC and MAC) dont see some USB devices when they are plugged in a second time between reboots.
Ye I followed all the steps as stated in the txt file and tried the file u mentioned but I’m still getting nothing dunno if the eeprom or usb chip is knackered, i’ve search tracks and all look good…
The ez-usb control panel just hangs when i try an upload the file…
thats correct, the whole windows system hangs during the EEPROM upload procedure. It also hangs some time when the MIDI driver is running and the USB cable is disconnected. But it should be recovered after about 30 seconds (this strange behaviour was also very confusing to me).
You can always ensure that the USB chip is working by downloading the .hex file into SRAM (->use the Download button, not the EEPROM button for this test)
a track hadnt come out in the etching process which ties one of the eeprom pins to ground so i blotched in a blob of solder and low and behold the eeprom is behaving now
Was etching the layout difficult with some of the small traces, and what process did you use (including what paper if you did toner transfer) to etch?
I don’t think I can make the USB layout much more home etch friendly but I am interested in whether it presents a problem to for those using toner transfer.
I have been using press’n’peel, which works well if you have a photocopier that is in pristine condition… most of my efforts needed a lot of cleaning up with a sharp knoife. In future I will be ordering my pcb’s from you smash, or the other guy… mike i think? I’m sick of sharpening 0.8mm drills all the time!! (HSS)
Yeah, I used pnp blue, However the laser i put em thru is not that great (laserjet 4) - so the tracks are never that clean, but at least it’s summin to work with…
does this mean that only the first out is affected, or both MIDI Outs?
To the SysEx issue: that’s the M$ driver bug which is descriped at the USB module page:
The Microsoft driver isn’t able to send one SysEx string which is distributed over multiple buffers without errors. The complete SysEx string has to be sent from a single buffer (this affects the MIOS download, in the MIDI-Ox port config menu, you have to increase the Low level Output buffer size from 256 to 2048 ).
Note: this means also that the SysEx upload to PIC16F cores cannot be realized w/o a change in the vmidibox editor. MIDI-Ox cannot be used to upload a dump to PIC16F based MIDIboxes.
It’s just MIDI Out 1 that is affected Out 2 outputs midi fine…
The sysex msg i typed before is what comes out of midi out 1 when it should be ie, transmitting note events from a logic seq track(which transmit fine on out2) but instead i just get that sysex msg…
after putting win XP on my laptop (before Win98se) my USB module is working very nicely. One thing i recogniced is, that after moving few times, my Usb port stops scanning( not the USb module though). After sending something from the port to the USb module its fine again. and so on. Any idea?
Sweet!
Have fun!
Smash
Etching was easy but i was just wondering why you did this MidiIn1;MidiIn2;MidiOut2;MidiOut1, frontpanel arrangment?
