usb mass storage driver
hi,
i’ve now got 2 functional core32’s.
my problem is neither of them work properly as mass storage,
i only need to copy the hwcfg file for wilba’s seq pcb!
no card reader so i thought i could just use the mass storage .hex, i guess the connections are right because the seq v4 says sd connected.
it’s a 4gb microsd card with a sd to microsd adaptor.
when i restart core32 after .hex upload windows detects and installs driver but then says i have to format, which then fails? telling me to check connections. :unsure:
if i click on the drive letter it says to insert disk in drive!
hope i’m right without res. network in R30 and jumpered 3v3.
now tried both core’s & 2 pc’s with similar results, any ideas??
:twitch:
Hi.
Do you know what type of SD card it is? I committed some changes to the SD driver last month to support MMC and SDHC cards which may not be in the pre-compiled mass storage.hex.
4GB cards are often SDHC ones so this may be the problem?
Cheers
Phil
thanks phil and i thinks you hit it on the head again.
i hooked up a 1gb sd card (soldered straight to pins) and bam away it went.
so now i was worried my 4gb would be useless, but you’re right it’s microSDHC.
4gb was cheaper than 2gb!
so i will grab that source @ svn?
my laptop with toolchain had hdd meltdown, so i only have win7 x64 here now, is it still possible to compile on x64 using the toolchain setup found on wiki here?
http://www.midibox.org/dokuwiki/doku.php?id=windows_mios32_toolchain_core
thanks!
No problem,
I use Windows 7 x64 and the standard toolchain works fine!
Cheers
Phil
ok,
compiled & uploaded, recognised and formatted.
just 1 problem = my 4gb formatted to 128kb! :shocked:
read & write no prob.
anyone else using 4gb microsdhc?
:logik: are we able to format when connected via mbseq with usb-msd mode?
:sweat: is partitioning 2x2gb gonna work? (part. software gone with laptop hdd or would have tried already)
That’s great :slight_smile:
Not so great :mad:
I am not using MicroSDHC but I guess it is the same technology as SDHC and the mods that I made to the MIOS32 driver were tested on a 4GB SDHC
Now this is the question… I have never tried but I will give it a go when I get home. My MB SEQ is running the latest CVS version. I have various different types of SD/MMC card so I will give it a go. I guess that this is a bit beyond the usb-msd mode goals of providing an easy method of copying files to and from SD cards though :slight_smile:
It ‘may’ work :slight_smile: MBSEQ wouldn’t be able to use the second partition though…
The msd module is an adaptation of the ST example code and is actually quite complex (it emulates a SCSI device!) but I don’t know how thoroughly things like formatting have been tested (if at all!)
Cheers
Phil
