USB Mass Storage device STM32
well @ least it’s not zero anymore..
[1036398.809] ====================
[1036398.809] SD Card Tools
[1036398.809]
[1036398.898] SD Card has been connected!
[1036398.902] Mounting SD Card…
[1036398.904] SUCCESS: SD Card mounted!
[1036415.906] csd
[1036415.895] --------------------
[1036415.895] - CSDStruct: 1
[1036415.895] - SysSpecVersion: 0
[1036415.895] - Reserved1: 0
[1036415.895] - TAAC: 14
[1036415.895] - NSAC: 0
[1036415.895] - MaxBusClkFrec: 50
[1036415.895] - CardComdClasses: 1461
[1036415.895] - RdBlockLen: 9
[1036415.895] - PartBlockRead: 0
[1036415.895] - WrBlockMisalign: 0
[1036415.895] - RdBlockMisalign: 0
[1036415.895] - DSRImpl: 0
[1036415.895] - Reserved2: 0
[1036415.895] - DeviceSize: 7559
[1036415.895] - MaxRdCurrentVDDMin: 0
[1036415.895] - MaxRdCurrentVDDMax: 0
[1036415.895] - MaxWrCurrentVDDMin: 0
[1036415.895] - MaxWrCurrentVDDMax: 0
[1036415.895] - DeviceSizeMul: 240
[1036415.895] - EraseGrSize: 31
[1036415.895] - EraseGrMul: 28
[1036415.896] - WrProtectGrSize: 0
[1036415.896] - WrProtectGrEnable: 0
[1036415.896] - ManDeflECC: 0
[1036415.896] - WrSpeedFact: 2
[1036415.896] - MaxWrBlockLen: 9
[1036415.896] - WriteBlockPaPartial: 0
[1036415.896] - Reserved3: 0
[1036415.896] - ContentProtectAppli: 0
[1036415.896] - FileFormatGrouop: 0
[1036415.896] - CopyFlag: 0
[1036415.899] - TempWrProtect: 0
[1036415.899] - FileFormat: 0
[1036415.899] - ECC: 0
[1036415.899] - msd_CRC: 0x28
[1036415.899] - Reserved4: 1
[1036415.899] --------------------
[1036431.859] format yes
it appeared hung here so i rebooted.
only then did mios studio say:
[1036683.414] Formatting SDCARD…
[1036683.414] [GET_SECTOR_COUNT] Count is 7741440
[1036683.414] [GET_BLOCK_SIZE] Block Size is 0
[1036683.414] [disk_write] error while writing to sector 13973
[1036683.414] Disk Function Error
[1036683.415] SD Card disconnected!
[1036683.417] [disk_initialize] error while checking for SD Card (status 0)
[1036683.417] [disk_read] error while reading sector 0
[1036683.417] Failed to open directory / - error status: 1
so it was formatting? but REALLY slowly?
how long should it take?
:ahappy:
progress!
s.
It should be pretty quick (a few seconds)…
This looks like another CSD issue:
This should be (16<<csd.DeviceSizeMul) although for some reason your DeviceSizeMul is 240 and 16<<240 will wrap quite a few times. I would expect DeviceSizeMul to be between 7 and 9 !!!
Leave it with me for a while and I will see what I can do :slight_smile:
Cheers
Phil
Oops, double post (it looked like it had hung!)
OK try it now.
I have tried another option which uses: 16 << (csd.DeviceSizeMul>>4) which should be a more reasonable number.
Try the latest svn!
Cheers
Phil
somethings not right, but it’s close (very close even).
[1083763.251] Formatting SDCARD…
[1083763.251] [disk_init] size = 4294967295
[1083763.251] [GET_SECTOR_COUNT] Count is 7741440
[1083763.251] [GET_BLOCK_SIZE] Block Size is 524288
[1083763.251] [disk_write] sector 0 (#1/1)
…this took ~3hrs!
[1093998.712] [disk_write] sector 524351 (#1/1)
[1093998.712] [disk_write] sector 64 (#1/1)
[1093998.849] [disk_write] sector 70 (#1/1)
[1093998.849] Operation completed successfully
then..
[1095689.218] filesys
[1095689.217] [disk_init] size = 4294967295
[1095689.217] [disk_read] sector 0 (#1/1)
[1095689.217] [disk_read] sector 63 (#1/1)
[1095689.217] [disk_read] sector 64 (#1/1)
[1095689.217] 64 sector/s per cluster, 112770 clusters.
[1095689.217] 524192 sectors per FAT, first FAT at sector #96, root dir at #2.
[1095689.217] 0 root dir entries (not valid for FAT32)
[1095689.217] Filesystem: 0x03 (FAT32)
is it usable now? :ermm:
…this took ~3hrs!
That may be my fault… I inadvertantly left debugging on when I committed my last change. That logs every read and write to MIOS Studio which will “massively” slow the operation down :slight_smile:
It should be quite a bit quicker now.
Cheers
Phil
