hi, the problem would be that you need a usb host (host as in “additional functionality”) providing midi conversion. afaik, the core32 offers only a mere usb standard device, so it will be difficult, but i am happy to be told different
The “Host” takes on a bigger part of the transfer responsibility, it’s a lot more than just a simple converter.
There is a new standard called “USB on the Go” that allows devices to talk directly without a host in between, but we have not seen much with that yet.
Another issue is driver compatibility. There is a “standard” driver for MIDI devices, but many devices come with their own private drivers.
Some (like Roland/Edirol) have a switch on the interface that lets you choose one or the other.
It should be a lot simpler, but sometimes it’s just not. Using USB ports means that a PC user won’t need a MIDI interface, but that assumes you want to connect to a PC and not between other types of musical gear.
I understood about the ´´host/driver compatibility´´ mentioned. But, thinking around, Instead of a ´´generic´´ USB MIDI out to old DIN MIDI Out converter, that could convert all kind of messages from all gears that have a MIDI USB out, it could be possible (and easier maybe) to develop just some specific solution for some specific host? Eg. Something to convert the USB MIDI out from a Axiom keyboard (a good example because it is a keyboard which sells a lot) to the old MIDI style socket (DIN)? It only could read the MIDI from that keyboard, no other. Convert, then throw it to a old DIN MIDI out port.
Sorry for resurrecting this thread from the last year, but I´m get more and more intrigued with this subject. I wish it have a commercial solution for this, but I can´t find.
But it just seems ridiculous that these days people have accepted USB Midi and bitch about something NOT having it so no we need something like that thing (which has gotten poor reviews from what I hear) to convert midi over USB BACK to DIN5 midi
Sure. I really don´t know why people don´t care with this functionality. There´s hundred of old synth-modules going cheap, such as the ones from Kurzweil, Korg, etc, that only have the DIN5 MIDI in PORT (of course). Also, Midibox synths just have that port.
Thanks for the link! The product looks very new also pretty expensive. But I´ll consider that as a option. Actually it´s the price of the solution to convert USB to old MIDI DIN that I´m using (Netbook running a MIDI router software + Cables)
Looks like the best and simple solution is plan the setup to the the old MIDI. Eg, buying a new keyboard with the DIN MIDI
Or just pray for someone experienced in the MIOS32 programming make such solution for the convertion :whistle:
Hi, if it worked (and not the USB-host part is kind of a hardware restriction) it would be lotsa work to code… I´d really go the old “DIN” way and boycot any keyboards/synths that don´t have these sockets
I was surprised the Korg Nanopad didn’t have DIN MIDI. I didn’t buy it specifically, it came bundled with software, but I thought it might make an interesting controller.
I only use a computer for recording so USB to DIN MIDI would be pretty cool really
EDIT: of course the full sized DIN wouldn’t fit, but I expected a break out cable. I obviously didn’t do my homework.
