upload problem
hi, i have pic core, pcb & components are functional, bootloader burned sucesfull and the upload query is this:F0 00 00 7E 40 70 01 F7  but if i want upload mios, there was this error message:
Starting upload of mios_v1_9f_pic18f452.hex
Requesting reboot…
Waiting for upload request…
Received unexpected MIOS SysEx message = 00007E407001F7  expected = 00007E3200
i tested input datas with oscilloscope at 26RX pin on pic and data were there
pls help, i bough 3rd pic & dont know what is problem
Just Guessing..
What is the PIC device ID?
This was burned in with the bootloader, and is used to identify some important options in your core.
all 8 IDs are set to 00
Looks like it receives another upload request - are you positive the midi In is working on the core side?
i said that i tested input port RX on processor with oscilloscope and there were data, and i tested 3rd processor, all 3 same result
What is displayed in the MIDI IN Monitor window of MIOS Studio?
And which operating system / MIDI Interface are you using?
this is repeating “upload” message
00000000014535 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000017217 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000019116 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000021015 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000022913 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000024812 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000026711 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000028610 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000030509 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000032408 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000034307 ms | SysEx: F0 00 00 7E 40 70 01 F7
00000000036206 ms | SysEx: F0 00 00 7E 40 70 01 F7
OS:Win XP pro
sound: ESI Juli@
interface is classical 5din midi cabel
Ok, apparently the Device ID of your PIC is 70 instead of 00:
Solution: upload the change_id application (can be found in the MIOS download area) with device ID 70 selected in MIOS Studio. It will program a new ID, so that you can select Device ID 00 thereafter.
where did you set this? Something was wrong there…
thx u much, changing id solved problem, now everything working
