Hello everyone..
I have updated the master core of my MB-6582 successfully to MIOS 1.9g / MBSID 2.0RC37 using MIOS Studio. However, now I need to update the slave too.
I was looking at http://www.ucapps.de/mios_bootstrap_newbies.html and found this information:
the Expert method: select the “Don’t use feedback from core” option in the upload window of MIOS Studio, ensure that you’ve loaded the right .hex file and you’ve selected the right device ID. Enable the MIDI merger of the master by pressing the Link button on the control surface (if you haven’t built it yet, you should prefer the newbie method), and press the start button - MIOS Studio will send all code blocks without waiting for a response. This method is easy to handle, but also dangerous if a block hasn’t been received completely (e.g. on an unstable MIDI connection), because you won’t get a notification. Therefore please select “Use feedback from core” so long a bidirectional connection is possible.
Even though I am no expert, I’d like to try this method. Thus I have a couple of questions:
Is the “Link” button that is referred in the text the same button as “Shift” button in MB-6582 control surface? Does the “Shift” button function in the same way? Should I keep it pressed while I press “Start” in MIOS studio or does a single press of the button suffice?
If I use this method, I need to select Device ID 1 for the slave (as the master is 0), is this correct? Or do I need to check the device ID somewhere?
The slave core uses 6581 SIDS (master core uses 6582), but I still need to upload setup_mb6582.hex to slave core too after uploading MIOS 1.9g, is this correct?
Thank you again, if anyone is willing to help a newbie who would like to use the “expert” method..
Regards,
