ui_store_file_required
Hey all,
Has anybody had a problem compiling the seq V4 firmware with the ui_store_file_required ?
I keep having "UNDIFINED REFERENCE TO ‘ui_store_file_required’
I am using the latest files on the SVN?
does anybody have an idea what this might couse?
cheers,
Jef
I have looked further and my guess is that in ui.c there should also be:
u8 ui_store_file_required;
cheers,
Jef - I don’t know whats going on with this but I find the define located in “seq_ui.c” file with a reference in “seq_ui.h”.  The revision header for seq_ui.c is:  // $Id: seq_ui.c 2102 2014-12-15 17:40:04Z tk $    I got this information directly from the SVN.MIOS32 repositories on line.
Are you using version 2102 for that file which was changed on 15-Dec?
Pete
Pete,
thx for the reply.
I have been having a few problems with SVN, but I can see the latest version now, and you are right it was already in there.
my bad
cheers,
Jef
I understand about your problems with the SVN.  I just don’t have enough experience in using it.  The most I have done is do diff’s between the original version that is stored on my PC.  I’m too afraid to try to do an update in my sandbox for fear that I will have problems with merging changes in the same files that others have changed.  From my previous knowledge with version control systems I know it can be done but I just don’t need it for what I am doing.  It is nice that TK has used a naming convention that helps pin point where the variable or function is located.
Pete
Here a hint how you can retrieve the changes from an “official place” in order to get an impression about possible reasons for such issues.
Go to http://svnmios.midibox.org
Select the MIOS32 repository, and then click on the “View logs” button.
Check the comments, they are sometimes helpful.
Select the potential problematic version with a “known good” one, or whatever you want to compare.
Then click on the “show changed files” button:
This gives you a nice looking diff over all changes:
And with some luck you will find out quickly, that the variable has been declared in seq_ui.c :slight_smile:
I’m using this web based method as well whenever somebody reports a problem after firmware changes in order to find out what I did :wink:
thx  Thorsten,
Happy New year
Jef
