ubuntu linux - make arm-none-eabi-gcc: error
the system:
ubuntu 15.10, 32bit
every time i have problems when i come with a new linux system… ours of ours of trial and error…
the error message:
triggermatrix@aha:~/mios32/trunk/apps/tutorials/016\_aout$ make rm -f project.hex arm-none-eabi-gcc: error: .ld: No such file or directory /home/triggermatrix/mios32/trunk/include/makefile/common.mk:139: recipe for target 'project\_build/project.elf' failed make: \*\*\* [project\_build/project.elf] Error 1
it creates object files,  but then the error, e.g.:
triggermatrix@lap:~/mios32/trunk/apps/tutorials/027_scs$ make
rm -f project.hex
Creating object file for app.c
Creating object file for scs_config.c
scs_config.c:53:13: warning: 'stringDecPM' defined but not used [-Wunused-function]
scs_config.c:55:13: warning: 'stringHex2' defined but not used [-Wunused-function]
Creating object file for cc_labels.c
Creating object file for main.c
Creating object file for strtol.c
Creating object file for tasks.c
Creating object file for list.c
Creating object file for queue.c
Creating object file for timers.c
Creating object file for port.c
Creating object file for umm_malloc.c
Creating object file for startup_LPC17xx.c
Creating object file for mios32_srio.c
Creating object file for mios32_din.c
Creating object file for mios32_dout.c
Creating object file for mios32_enc.c
Creating object file for mios32_lcd.c
Creating object file for mios32_midi.c
Creating object file for mios32_osc.c
Creating object file for mios32_com.c
Creating object file for mios32_uart_midi.c
Creating object file for mios32_spi_midi.c
Creating object file for mios32_iic_midi.c
Creating object file for mios32_iic_bs.c
Creating object file for mios32_mf.c
Creating object file for mios32_sdcard.c
Creating object file for mios32_enc28j60.c
Creating object file for mios32_timestamp.c
Creating object file for mios32_bsl.c
Creating object file for mios32_sys.c
Creating object file for mios32_irq.c
Creating object file for mios32_spi.c
Creating object file for mios32_i2s.c
Creating object file for mios32_board.c
Creating object file for mios32_timer.c
Creating object file for mios32_stopwatch.c
Creating object file for mios32_delay.c
Creating object file for mios32_ain.c
Creating object file for mios32_usb.c
Creating object file for mios32_usb_midi.c
Creating object file for mios32_usb_com.c
Creating object file for mios32_uart.c
Creating object file for mios32_iic.c
Creating object file for printf-stdarg.c
Creating object file for core_cm3.c
Creating object file for usbhw_lpc.c
Creating object file for usbcontrol.c
/home/triggermatrix/mios32/trunk/drivers/LPC17xx/usbstack/src/usbcontrol.c: In function 'StallControlPipe':
/home/triggermatrix/mios32/trunk/drivers/LPC17xx/usbstack/src/usbcontrol.c:127:6: warning: variable 'pb' set but not used [-Wunused-but-set-variable]
Creating object file for usbstdreq.c
Creating object file for usbinit.c
Creating object file for app_lcd.c
Creating object file for glcd_font_normal.c
Creating object file for glcd_font_normal_inv.c
Creating object file for glcd_font_big.c
Creating object file for glcd_font_small.c
Creating object file for glcd_font_tiny.c
Creating object file for glcd_font_knob_icons.c
Creating object file for glcd_font_meter_icons_h.c
Creating object file for glcd_font_meter_icons_v.c
Creating object file for scs.c
Creating object file for scs_lcd.c
Creating object file for mini_cpp.cpp
Creating object file for freertos_heap.cpp
/home/triggermatrix/mios32/trunk/include/makefile/common.mk:139: recipe for target 'project_build/project.elf' failed
make: *** [project_build/project.elf] Error 1
my environment variables:
PATH="/home/triggermatrix/mios32\_toolchain/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games" MIOS32\_PATH="/home/triggermatrix/mios32/trunk" MIOS32\_BIN\_PATH="/home/triggermatrix/mios32/trunk/bin" MIOS32\_GCC\_PREFIX=arm-none-eabi MIOS32\_FAMILY=LPC17xx MIOS32\_PROCESSOR=LPC1769 MIOS32\_BOARD=MBHP\_CORE\_LPC17 MIOS32\_LCD=universal
Mios32 is located under: /home/triggermatrix/mios32 , in there are the folders: “playground” and “trunk”
toolchain is located under: /home/triggermatrix/mios32_toolchain , in there are the folders: “arm-none-eabi” “bin” “lib” “share”
i have already installed:
sudo aptitude install subversion
sudo aptitude install build-essential
sudo aptitude install libgmp3-dev
i removed and installed, the thoolchain, mios32, essential, gcc, libgmp3  several times…nothing helped.
what do i miss?
Hola and a happy new year! :slight_smile:
Strange problem, could you rerun with a “make --trace” and copy & paste the region just above the error (not the full dump, that would be rather long ;-))?
So we know, which exact command is being executed that causes the problem…
Many greets!
Peter
oh, a white new year…
–trace, a new word, cool.
it starts with that:
triggermatrix@lap:~/mios32/trunk/apps/tutorials/020_lcd$ make --trace
/home/triggermatrix/mios32/trunk/include/makefile/common.mk:118: target 'dirs' does not exist
if [! -e project_build]; then mkdir project_build; fi;
if [! -e project_build/./]; then mkdir -p project_build/./; fi; if [! -e project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/]; then mkdir -p project_build//home
end ends with that:
arm-none-eabi-gcc -Wp,-MMD,project\_build//home/triggermatrix/mios32/trunk/programming\_models/traditional/startup\_stm32f4xx.dd -g -Os -DGCC\_ARMCM3 -DMIOS32\_PROCESSOR\_STM32F407VG -DMIOS32\_FAMILY\_STM32F4xx -DMIOS32\_FAMILY\_STR=\"STM32F4xx\" -DMIOS32\_BOARD\_MBHP\_CORE\_STM32F4 -DMIOS32\_BOARD\_STR=\"MBHP\_CORE\_STM32F4\" -DMIOS32\_LCD\_universal -DMIOS32\_LCD\_STR=\"universal\" -DUSE\_STDPERIPH\_DRIVER -DUSB\_SUPPORT\_USER\_STRING\_DESC -I . -I /home/triggermatrix/mios32/trunk/programming\_models/traditional -I /home/triggermatrix/mios32/trunk/FreeRTOS/Source/include -I /home/triggermatrix/mios32/trunk/FreeRTOS/Source/portable/GCC/ARM\_CM3 -I /home/triggermatrix/mios32/trunk/FreeRTOS/Source/portable/MemMang -I /home/triggermatrix/mios32/trunk/include/mios32 -I /home/triggermatrix/mios32/trunk/mios32/STM32F4xx -I /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/STM32F4xx\_StdPeriph\_Driver/inc -I /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/STM32\_USB\_Device\_Library/Core/inc -I /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/STM32\_USB\_HOST\_Library/Core/inc -I /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/STM32\_USB\_OTG\_Driver/inc -I /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/CMSIS/Include -I /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/CMSIS/ST/STM32F4xx/Include -I /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/CMSIS/ST/STM32F4xx/Include -I /home/triggermatrix/mios32/trunk/modules/app\_lcd/universal -I /home/triggermatrix/mios32/trunk/modules/glcd\_font -Wall -Wno-format -Wno-switch -Wno-strict-aliasing -mcpu=cortex-m4 -mlittle-endian -ffunction-sections -fdata-sections -fomit-frame-pointer -mthumb -c /home/triggermatrix/mios32/trunk/programming\_models/traditional/startup\_stm32f4xx.c -o project\_build//home/triggermatrix/mios32/trunk/programming\_models/traditional/startup\_stm32f4xx.o arm-none-eabi-gcc: error trying to exec 'cc1': execvp: No such file or directory /home/triggermatrix/mios32/trunk/include/makefile/common.mk:160: recipe for target 'project\_build//home/triggermatrix/mios32/trunk/programming\_models/traditional/startup\_stm32f4xx.o' failed make: \*\*\* [project\_build//home/triggermatrix/mios32/trunk/programming\_models/traditional/startup\_stm32f4xx.o] Error 1
Check if /usr/bin/cc is present. If so then do:
ln -s /usr/bin/cc /usr/bin/cc1
it was present, cc1 was not, with your command, it had created cc1
after rebooting the following error messages:
mlittle-endian -ffunction-sections -fdata-sections -fomit-frame-pointer -mthumb -c /home/triggermatrix/mios32/trunk/programming_models/traditional/startup_stm32f4xx.c -o project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/startup_stm32f4xx.o
cc1: error: unrecognized command line option ‘-quiet’
cc1: error: project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/startup_stm32f4xx.dd: Datei oder Verzeichnis nicht gefunden
cc1: warning: ‘-mcpu=’ is deprecated; use ‘-mtune=’ or ‘-march=’ instead
cc1: error: unrecognized command line option ‘-auxbase-strip project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/startup_stm32f4xx.o’
cc1: error: unrecognized command line option ‘-mlittle-endian’
cc1: error: unrecognized command line option ‘-mthumb’
/home/triggermatrix/mios32/trunk/include/makefile/common.mk:160: recipe for target 'project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/startup_stm32f4xx.o' failed
make: *** [project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/startup_stm32f4xx.o] Error 1
Ok, it is a little strange, as we are dealing with two types of errors:
First one:
And now:
Creating the softlink in the /usr/bin directory linked in a compiler frontend not from the toolchain, but from the base system, so the very last errors regarding the wrong command line options are understandable - the /usr/bin/cc compiler does not understand the architecture settings.
The “wanted” cc1 target should reside in your toolchain directory under lib/gcc/arm-none-eabi/4.7.4/cc1 (or a similar path, if you are using a slightly different version).
Can you give us a listing of that directory?
Whenever you execute
arm-none-eabi-gcc
this one should reside in your toolchain directory. To confirm that, enter
type arm-none-eabi-gcc
which lists the path of the executable, that will be loaded.
If it is in the toolchain directory, it should automatically look for “cc1” in the respective directory. If it is not there, the toolchain installation might be incomplete.
I am personally not using linux, but a freebsd-based toolchain and therefore don’t know for which platform the linux toolchain was made, if it was made for a 64bit platform, this might also be the reason (as you are using a 32-bit system) for these strange and different problems…
Well, good luck! :slight_smile:
Many greets,
Peter
i always used a 32bit linux the last 2 years… ubuntu 12, 14, and now 15… in theorie it should work,
triggermatrix@lap:~/mios32/trunk/apps/tutorials/020_lcd$ arm-none-eabi-gcc
arm-none-eabi-gcc: fatal error: no input files
compilation terminated.
triggermatrix@lap:~/mios32/trunk/apps/tutorials/020_lcd$ type arm-none-eabi-gcc
arm-none-eabi-gcc gehasht ergibt (/home/triggermatrix/mios32_toolchain/arm-none-eabi/bin/arm-none-eabi-gcc)
well it put out the correct path… and in this path exist a file called “arm-none-eabi-gcc”
Ok!
Can you
ls -al /home/triggermatrix/mios32_toolchain/lib/gcc/arm-none-eabi/4.7.4
(the directory version number might be slightly different).
Is there a “cc1” in this directory?
Many greets,
Peter
Another question, in the first post, you wrote, that the settings are set to
has this changed by now? Because it seems to be compiling for a STM32F4 target…
Many greets!
Peter
yes i changed it because i need to compile a program for STM32
yes there is a cc1:
triggermatrix@lap:~/mios32/trunk/apps/tutorials/020_lcd$ ls -al /home/triggermatrix/mios32_toolchain/lib/gcc/arm-none-eabi/4.7.4
insgesamt 41588
drwxr-xr-x 12 triggermatrix triggermatrix     4096 Sep 15  2013 .
drwxr-xr-x  3 triggermatrix triggermatrix     4096 Sep 15  2013 ..
drwxr-xr-x  2 triggermatrix triggermatrix     4096 Sep 15  2013 armv6-m
drwxr-xr-x  3 triggermatrix triggermatrix     4096 Sep 15  2013 armv7-ar
drwxr-xr-x  4 triggermatrix triggermatrix     4096 Sep 15  2013 armv7e-m
drwxr-xr-x  2 triggermatrix triggermatrix     4096 Sep 15  2013 armv7-m
-rwxr-xr-x  1 triggermatrix triggermatrix 13241452 Sep 15  2013 cc1
-rwxr-xr-x  1 triggermatrix triggermatrix 14159384 Sep 15  2013 cc1plus
-rwxr-xr-x  1 triggermatrix triggermatrix   254932 Sep 15  2013 collect2
-rw-r–r–  1 triggermatrix triggermatrix     1832 Sep 15  2013 crtbegin.o
-rw-r–r–  1 triggermatrix triggermatrix      817 Sep 15  2013 crtend.o
-rw-r–r–  1 triggermatrix triggermatrix      764 Sep 15  2013 crti.o
-rw-r–r–  1 triggermatrix triggermatrix      824 Sep 15  2013 crtn.o
drwxr-xr-x  2 triggermatrix triggermatrix     4096 Sep 15  2013 fpu
drwxr-xr-x  2 triggermatrix triggermatrix     4096 Sep 15  2013 include
drwxr-xr-x  2 triggermatrix triggermatrix     4096 Sep 15  2013 include-fixed
drwxr-xr-x  3 triggermatrix triggermatrix     4096 Sep 15  2013 install-tools
-rw-r–r–  1 triggermatrix triggermatrix  1611024 Sep 15  2013 libgcc.a
-rw-r–r–  1 triggermatrix triggermatrix    30720 Sep 15  2013 libgcov.a
lrwxrwxrwx  1 triggermatrix triggermatrix       22 Dez 31 19:13 liblto_plugin.so -> liblto_plugin.so.0.0.0
lrwxrwxrwx  1 triggermatrix triggermatrix       22 Dez 31 19:13 liblto_plugin.so.0 -> liblto_plugin.so.0.0.0
-rwxr-xr-x  1 triggermatrix triggermatrix    58732 Sep 15  2013 liblto_plugin.so.0.0.0
-rwxr-xr-x  1 triggermatrix triggermatrix 12701292 Sep 15  2013 lto1
-rwxr-xr-x  1 triggermatrix triggermatrix   343736 Sep 15  2013 lto-wrapper
drwxr-xr-x  3 triggermatrix triggermatrix     4096 Sep 15  2013 plugin
drwxr-xr-x  2 triggermatrix triggermatrix     4096 Sep 15  2013 thumb
my current environment variables are:
Quote
PATH=“/home/triggermatrix/mios32_toolchain/arm-none-eabi/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games”
MIOS32_PATH=“/home/triggermatrix/mios32/trunk”
MIOS32_BIN_PATH=“/home/triggermatrix/mios32/trunk/bin”
MIOS32_GCC_PREFIX=arm-none-eabi
MIOS32_FAMILY=STM32F4xx
MIOS32_PROCESSOR=STM32F407VG
MIOS32_BOARD=MBHP_CORE_STM32F4
MIOS32_LCD=universal
give me following error:
Quote
rm -f project.hex
cc1: error: project_build/app.dd: Datei oder Verzeichnis nicht gefunden
cc1: error: unrecognized command line option ‘-auxbase-strip project_build/app.o’
/home/triggermatrix/mios32/trunk/include/makefile/common.mk:160: recipe for target ‘project_build/app.o’ failed
make: *** [project_build/app.o] Error 1
Ok!
The current error is because of the softlink within /usr/bin, it links to the wrong compiler frontend
plz try:
rm /usr/bin/cc1
(this removes the problematic link)
ln -s /home/triggermatrix/mios32_toolchain/lib/gcc/arm-none-eabi/4.7.4/cc1 /home/triggermatrix/mios32_toolchain/arm-none-eabi/bin/cc1
(this adds a link of the correct cc1 to your in-path toolchain directory. This should not be necessary, but somehow the crosscompiler gcc does not know where to find it otherwise).
type cc1
(this should now output /home/triggermatrix/mios32_toolchain/arm-none-eabi/bin/cc1 and confirm, that cc1 is now in path and can be opened)
then recompile. I have a feeling other errors will follow, as other binaries within the lib/gcc directory are needed. But we should get a different error at least and can fix that problem with a PATH extension maybe.
Many greets,
Peter
Sorry i put you on the wrong path, forgot about our custom toolchain.
Quote
rm -f project.hex
In file included from /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/CMSIS/ST/STM32F4xx/Include/stm32f4xx.h:245:0,
                 from /home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/STM32F4xx_StdPeriph_Driver/inc/stm32f4xx_adc.h:32,
                 from /home/triggermatrix/mios32/trunk/programming_models/traditional/stm32f4xx_conf.h:34,
                 from /home/triggermatrix/mios32/trunk/include/mios32/mios32.h:34,
                 from app.c:19:
/home/triggermatrix/mios32/trunk/drivers/STM32F4xx/v1.1.0/CMSIS/Include/core_cm4.h:143:97: fatal error: stdint.h: No such file or directory
hmm
what is the result of
type cc1
now? Sorry for all that inconvenience! :slight_smile:
Many greets,
Peter
oooops - belästigung?  geh, danke für die hilfe
 resultat:
cc1 ist /home/triggermatrix/mios32_toolchain/arm-none-eabi/bin/cc1
and cc1 is a link “verknüpfung” is that correct?
edit:
verknüpfungsziel: /home/triggermatrix/mios32_toolchain/lib/gcc/arm-none-eabi/4.7.4/cc1
the orginal file for the link exists.
no problem! :slight_smile: yes, cc1 is now linked/verknüpft :slight_smile:
can you now please
make clean
and
make --trace
again?
Was there any progress? Do we now get past the previous point where “cc1 was missing”?
Many greets,
Peter
PS: Shuriken: no problem either, I first thought about recommending that “ln -s” in /usr/bin, too :).
make --trace begin with:
Quote
/home/triggermatrix/mios32/trunk/include/makefile/common.mk:118: target ‘dirs’ does not exist
if [! -e project_build/./]; then mkdir -p project_build/./; fi;   if [! -e project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/]; then mkdir -p project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/; fi;   if [! -e project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/]; then mkdir -p project_build//home/triggermatrix/mios32/trunk/programming_models/traditional/; fi;   if [ ! -e project_build//hom…
and ends with:
trunk/drivers/STM32F4xx/v1.1.0/CMSIS/ST/STM32F4xx/Include -I /home/triggermatrix/mios32/trunk/modules/app_lcd/universal -I /home/triggermatrix/mios32/trunk/modules/glcd_font -Wall -Wno-format -Wno-switch -Wno-strict-aliasing -mcpu=cortex-m4 -mlittle-endian -ffunction-sections -fdata-sections -fomit-frame-pointer -mthumb -c app.c -o project_build/app.o
                 from app.c:19:
/home/triggermatrix/mios32/trunk/include/makefile/common.mk:160: recipe for target 'project_build/app.o' failed
Ok, it is messed up, as it does not find the standard headers. I’ve looked into it a bit, can you try to adjust your PATH from
PATH="/home/triggermatrix/mios32\_toolchain/arm-none-eabi/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
To
PATH="/home/triggermatrix/mios32_toolchain/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
