Hi to all. First of all I’d like to thank the wonderful group of MIDIBoxers that really did a wonderful work.
I have two problems:
I have a 18F4685 but I cannot compile it (not in the Valid devices list). Actually I’m using the statement
PROCESSOR = 18f452 in my makefile (mios_base_v1_0b)
I have a core unit with a LCD, and I don’t know what pin to use (and how) for a Digital In. Are there any still available?
I have a FATAR masterkeyboard TMK88. Very cheap very light but very poor MIDI implementation (no velocity curves, just MIDI chn 1, no transposition, etc…). I had problems with black and white keys (different strenght for having the same velocity codes) and I already have successfully compensated it with separate black and white velocity response curves with my MIOS_CORE unit.
Now I’d like to add transpose caps as well as split, layers, etc…
I’m thinking to add a DIN input to enter a special modality and then press some keys of the keyboard to input data. Most master keyboards work in this way. But where should I have to connect the switch? Are there C examples? Do I need a DIN board?
18f4685 is supported by MIOS now… you’ve been gone a while AC ;D
oh yes… and I’m very bad with names: how should I remember all these PIC variants… I’m so glad when I succeed in remembering my 4-digit creditcard pin :
Honestly, the only PIC I remember without having to look it up is the PIC18F452 (though it could also be 18F542 now that I think about it)… even when it comes to the PIC16F I don’t know if its 88 or 84 or 66 or 68
