troubles with aout
Hi
I am testing my first AOUT module with aout_example_v1_4 - application and dont get the expected results:
Sending midi notes (with the help of MIOS Studio MIDI Keyboard Controller)signals doesnt change the voltage on pin #0 and #1 as expected after reading the aout_midi.inc.
The LCD Display shows the correct note pitch and veolicity.
The LED on the AOUT board is on.
The power connections are done according to http://www.ucapps.de/mbhp/mbhp_shx8_interconnections.pdf (without the SHX8 module of course, which would be the next step)
I test with help of a voltage-meter connect between v1 resp. v2 and (J2-)Vs
any hints or ideas are very welcome
thanks
martin
** ADDITIONAL INFO **
I was able to run MidiBox CV, so the hardware works fine. But I am still not able to run the AOUT testapplication on my setup. Since I plan to run the AOUT with a SHX8 module, myissue is resolved. SO up to the next challenge..
(However, there is a little itch)
