trouble uploading sid program
Ok, figured out my midi in troubles (at least I think?) I can now get MIOS uploaded to my core and everything seems to be working fine. I then go to upload the SID program and it goes fine until I get to:
Sending block 000080000-000080FF
Recieved error code 05: Write Access failed (invalid address range) - used by 1st level bsl
It tries 16 times and aborts the upload. After that, my midi in reads the following messages alternating every 2 secs:
“Sysex message: F0 00 00 7E 40 00 01 F7”
“[EE 02 04] Channel 15: Pitch Bend value: 514”
Also, my LCD displays, “Rebooting MIOS”
After all this, if I reupload MIOS everything starts all over again. After reuploading MIOS, my LCD displays, “Ready.” and I get the single “Sysex message: F0 00 00 7E 40 00 01 F7” Then, I try to upload sid program again… same thing all over.
I’m lost.
What kind of PIC are you using? It’s failing at the 64k limit as though there’s no 4685 there…
Using the PIC18F452 from SmashTV with BSL 1.2B
What Version of midibox sid do you upload, v1 or v2?
Please try this again:
http://www.ucapps.de/mios/midibox_sid_v1_7303b.zip
Greetings
Yes!!! Thanks again midiboxxer!!! I am now officially up and running! My midibox is making sounds, and I love it! Thank you all.
Great to hear!  :wink:
