Triggering RunSection execution
This works:
EVENT_BUTTON id=1 fwd_id=LED:40 button_mode=OnOff type=Meta meta=RunSection:15
but any other kind of method to launch a RunSection I’ve tried has not succeeded.
In particular I’d like to launch a RunSection following an encoder change:
EVENT_ENC id= 66 hw_id= 66 fwd_id=BUTTON:1 fwd_to_lcd=1 chn=1 type=ProgramChange range=0:127 label="^prgch"
I’ve tried to forward to other types of EVENT_ that have meta=RunSection but nothing works except the pressing the button that has meta=RunSection.
What is a working method to forward from an encoder change to trigger a RunSection execution?
I’m surprised! Could you please give me a concrete example for a fwd combination which doesn’t work?
#this works
#this don't
###Dump request
EVENT_BUTTON id=500 type=Meta meta=RunSection:15 button_mode=OnOff
####Progchange -> Dump request
EVENT_ENC id= 66 hw_id= 66 fwd_id=BUTTON:500 fwd_to_lcd=1 chn=1 type=ProgramChange range=0:127 ports=1000100000001000 enc_speed_mode=Slow:4 label="^prgch"
Here’s the NGR
if ^section == 15
    LCD "@(1:1:1)about to..."
	LOG "about to..."
    delay_ms 1000
	LCD "@(1:1:1) dump "
	LOG "dump"
exit
endif
With “fwd=BUTTON:500” you will forward a the value to the button, but this won’t trigger a MIDI event.
This is intended - e.g. let’s assume the case, that you forward a value from a button to a LED - in this case you definitely don’t want that the LED sends a second MIDI event.
The usage of EVENT_SENDER should help here.
Try this:
##dump request
EVENT_SENDER id=500 type=Meta meta=RunSection:15
####Progchange → Dump request
EVENT_ENC id= 66 hw_id= 66 fwd_id=SENDER:500 fwd_to_lcd=1 chn=1 type=ProgramChange range=0:127 ports=1000100000001000 enc_speed_mode=Slow:4 label=“^prgch”
Works! (I thought I’d tried this)
Thanks TK!
Now, to a closely related matter:
For a bank change, I need to follow the bank change CC with the current ProgramChange+Dump request.
but
###Bank Select -> Progchange -> Dump request
EVENT_ENC id= 65 hw_id= 65 fwd_id=ENC:66 fwd_to_lcd=1 chn= 1 type=CC cc=0 range=0:7 ports=1000100000001000 enc_speed_mode=Slow:4 label="^banksel"
this updates the program change LCD with the bank change value. Additionally, it does not result in the sending of ProgramChange, just bank CC.
[edit] it does trigger the RunSection associated with ENC:66 though [/edit]
I would just like to trigger transmission of the existing program change value.
How to do this?
of course, because fwd_id will forward the received value to the next event
(e.g. forwarding a button value to a LED)
E.g. you could use the “trigger” command in your .NGR script to trigger the transmission of ENC:65 and ENC:66
This seems to work o.k, thanks TK.
