The clock pulse can be varied in ms steps, but the triggers are either gate or 1ms. Does it work to use “gates” instead? Often a trigger input will react on the rising edge. If it’s the falling edge though, then a gate wouldn’t help.
I had a quick look through the code, but I couldn’t find an obvious solution. Clocks are different to triggers, as the timing is always consistent relative to the master tempo.
Same!
It seems the DOUT triggers can be enabled in the hardware config file by " DOUT_1MS_TRIGGER" then the variable seq_hwcfg_dout_gate_1ms is set from this text command but I don’t find where this variable is used, so I can tell how this is used, even less how to change its length.
I think we have to call for that, he’s the only one who can explain how and what is doable.
