Transparent soft push-buttons?
Does anybody know, where I can get transparent soft push-buttons (kind a rubber or silikone feel) from?
I wished the same…
well, maybe you can make silicon one your self, I didn’t try it… maybe it can be a solution.
i found this on maplins perhaps you could use the top part of these keytops.
http://www.maplin.co.uk/products/module.asp?CartID=040630130836632&moduleno=2533&Products=1
ed
… thanks shed! It’s not was I’m actually looking for but I’m already thinking, where I could use those :slight_smile:
Pilo: It could be possible. I think I’ll try it this way:
I’ll buy some 2 component silicone http://www.rai-ro.de/seite14.htm, take a steal tube (about 6cm long), polish the inside of it and fill the silicone into it. When it’s hardend, I push the silicone stick out of the tube and slice it with a carpet knive.
Possible problem:
I don’t know, about there is a paint which sticks on silicone for silksceen printing  ???
Roger
im sure you should be able to get coloured siliacone, i had some black stuff once, and also if it sets to a matt finish its usulay ok to paint,  you will lose the soft touch if you do paint them though.
