translation C -> assembler : need help !
hello,
I’m a C programmer I’d like to translate this function into assembler code (because it needs to be optimized) :
// Integer division (a div b)
unsigned int ADK_DIV(unsigned int a, unsigned int b)
  unsigned int reste = 0;
  unsigned char count = 16;
  char c;
  do
    c = ((a >> (8*sizeof(a)-1)) & 1);
    a <<= 1;
    reste <<= 1;
    if © reste |= 1;
    if (reste >= b)
      reste -= b;
      a |= 1;
  while (–count);
  return a;
Thanks for anybody who could help me !
Goule
Hi Goule,
in the clockbox application you will find an assembly based division routine in “mclock.c” (search for __asm)
However, here another hint: if your program just only converts value A to B based on static parameters, then you could also use a table (constant array) with the required number of entries. This is significantly faster, and for common CC’s it doesn’t consume that much memory (e.g. a table of 128 entries allocate the same memory like 64 instructions)
I’m normaly using perl scripts to calculate such tables, example:
#!/usr/bin/perl
print "const unsigned char exp_table[128] = {\n  ";
int i;
for($i=0; $i<128; ++$i)
  my $value = int(0x80 * (1-exp(-$i/32)));
  printf "0x%02x, ", $value;
  if( !(($i+1) % 8) ) { # linebreak
    printf "\n  ";
print "};\n";
[/code]
generates:
[code]
const unsigned char exp\_table[128] = {
&nbsp; 0x00, 0x03, 0x07, 0x0b, 0x0f, 0x12, 0x15, 0x19,
&nbsp; 0x1c, 0x1f, 0x22, 0x25, 0x28, 0x2a, 0x2d, 0x2f,
&nbsp; 0x32, 0x34, 0x37, 0x39, 0x3b, 0x3d, 0x3f, 0x41,
&nbsp; 0x43, 0x45, 0x47, 0x48, 0x4a, 0x4c, 0x4d, 0x4f,
&nbsp; 0x50, 0x52, 0x53, 0x55, 0x56, 0x57, 0x58, 0x5a,
&nbsp; 0x5b, 0x5c, 0x5d, 0x5e, 0x5f, 0x60, 0x61, 0x62,
&nbsp; 0x63, 0x64, 0x65, 0x65, 0x66, 0x67, 0x68, 0x69,
&nbsp; 0x69, 0x6a, 0x6b, 0x6b, 0x6c, 0x6c, 0x6d, 0x6e,
&nbsp; 0x6e, 0x6f, 0x6f, 0x70, 0x70, 0x71, 0x71, 0x72,
&nbsp; 0x72, 0x72, 0x73, 0x73, 0x74, 0x74, 0x74, 0x75,
&nbsp; 0x75, 0x75, 0x76, 0x76, 0x76, 0x77, 0x77, 0x77,
&nbsp; 0x77, 0x78, 0x78, 0x78, 0x78, 0x79, 0x79, 0x79,
&nbsp; 0x79, 0x79, 0x7a, 0x7a, 0x7a, 0x7a, 0x7a, 0x7a,
&nbsp; 0x7b, 0x7b, 0x7b, 0x7b, 0x7b, 0x7b, 0x7b, 0x7c,
&nbsp; 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c, 0x7c,
&nbsp; 0x7c, 0x7d, 0x7d, 0x7d, 0x7d, 0x7d, 0x7d, 0x7d,
&nbsp; };
