traktor midiout problem **update
Hi
I have an issue with the traktor midiout to midibox.
If I have it enabled with an output for a LED, the midibox doesnt work properly.
I have button 1 set as toggle for play and I an output for the same to the LED.
If I press the button, traktor plays and then stops playing after 1 second.
If I remove the output for the LED, the button works fine.
It seems to have problems with any output to the midibox.
Anyone else experience this?
I also tried this on the mpu401(gameport) and on serial with the roland driver.
with the midibox - if i press the button, the LED comes on for the duration of the button being press(this works using the midibox v2.4)
Now in MIOS and midiox, i press the key in the keyboard that generates the event as when pressing the button on the midibox, but the LED doesnt come on.
I have the port routings correct.
Should the LED come on when generating the event in mios or midiox provided that the event is the same as the channel that the LED is on.
************Update
Im now using midibox64e 2.2
The button now works with the midi output enabled and a output for the LED.
But the LED doesnt stay on…
The output for the LED is the exact same as the input for the button except that its an output type.
The LED does come on when I press the button(this is a normal function of the dout) even with the midibox in standalone mode
Did you change the LED_MAP, so that it is only controlled by the received MIDI status?
See also this posting http://www.midibox.org/forum/index.php/topic,6039.0.html
That worked. Thanks
