hey guys, this shop is right down the road from my house and i thought i might give this transformer a shot. i am pretty intimidated by the PSU part of this build. :-[ anyhow, will this transformer work? thanks.
[edit] looking at the pictures, i’d probably actually want this one…?
The second one is 24V centre-tapped, which is likely ideal for + 12V and - 12V.
Since you’re wiring mains-level AC to the other side, take precautions! Use some heat-shrinkable tubing to go over those connections so that you don’t give yourself a nasty jolt when you’re poking around with the power on. A fuse inside your enclosure would probably be a good idea here. Anything from a 1 amp to 5 amp AGC fuse will protect you from a dead short.
